Should I get a 226 Watt Peltier rather then a 176 Watt Peltier? I'll be water cooling so, I'm pretty postive it will take the heat. Will there be much peformance? There's only 2 dollar difference. Thanks in advance.
The 226 watt pelt is 50mm square verses 40mm for the 172. So along with the higher heat pumping ability, it has the advantage of more surface area. I would strongly suggest running watercooling for a while first, before you try pelts.
