- Nov 18, 1999
- 3,879
- 1
- 0
hola.
just got one of the duron 600's from buy.com. the comp is stable at 927 (9X103). i had it at 935 (8.5X110), but it just wasn't stable enough. i was able to boot the comp at 990 (9X110), but it choked loading windows.
could you guys start me off w/ some info for water cooling/peltier my cpu...thx
think it'll get 990 w/ the extra cooling??
thx in advance
btw, currently sys temp is 78 and cpu is at 96(inactive) and 11 (under load). i am using a globalwin fop-32-1 w/ arctic silver, i have a blow hole, 3 side fans (2 around the 4th pci slot (blowing in), and 1 above just under the cpu (blowing out), a harddrive cooler and 2 fans blowing air out of the case just above the ps.
AMD Duron600@927
(2) 128 meg sticks ram (1 is the mushkin budget pc133, the 2nd is pny pc100 ram) think some better ram might help?
leadtek geforce2mx @210/190 (gpu/memory)
ibm 13gb 7200 rpm ata66
sound blaster pci512
3com 3c905btx
abit kt7 raid w/ latest bios rev.
thx in advance
AMD Duron600@927
3com 3c905btx
