The SmartMount Universal Flat Wall Mount supports virtually any 23" to 46" LCD flat panel screen. The ultra-slim wall plate keeps the screen close to the wall for a very discreet installation that is perfect for boardrooms, digital signage, or home theaters. The mount includes simple to align universal brackets and a unique wall plate that can be mounted to one or two wood studs up to 16" apart, concrete, cinder block or two metal studs (accessory required). Includes a Sorted-For You? baffle pack with all screen hardware and security fasteners. Fits screens with mounting hole patterns up to 17.25" W and 12.94" H
# Universal mount fits virtually any 23" to 46" LCD flat panel screen
# Ultra-slim design holds screen only 1.18" from the wall
# Easy-glide bracket design ensures screen is securely attached to wall plate
# Mounts to one or two wood studs, concrete, cinder block or metal studs (accessory required)
# Horizontal screen adjustment up to 6"
# Comes with Peerless? Sorted-For-YouTM fastener pack with all necessary screen attachment hardware
# UL listed
Features
Dimensions: 19.25" x 13.75" x 1.18"
Weight: 4.9 lb (2.2 kg)
Maximum Load Capacity: 150 lb (68 kg)
Finish: Scratch Resistant Fused Epoxy
Package Contents: Wall plate, universal brackets and mounting hardware
Warranty: Limited 5-year
LINK
Not for use with Plasma TV's
# UL listed
Features
LINK
