Peer Guardian 2 Replacement
lorddwar
Recently, Peer Guardian 2 decided to stop blocking IPs like it had been for 2 years. A search of their website left me disenchanted to the hope of a fix since there were numerous other complaints about this same issue.
Does anyone know of any other programs out there with the same IP blocking functionality as PG2?
Thank you,
Lord Dwar
lorddwar
Thanks.
I had to uninstall, delete the directory, and reinstall to get it to work again. A simple reinstall didn't cut it.
Still, if anyone knows of an alternative I would like to know so I have a backup ready to go.
Thank you.
Dwar
OVERKILL
2,103
Originally posted by: l:eek:rddwar
Thanks.
Thank you.
Dwar
I've used Protowall for a long time.
It works fine. :thumbsup:
Entropism
236
I have a blocklist generated by BlockList manager (free program), loaded into my uTorrent. Works like a dream.
