peak oil is a eco-KOOK hoax along with all the other ritualistic eco-CRAP.
Ahhh, there we go, the kooky quota's been met.
The oil companies aren't stupid, they have to know about this.
At least two have even made mention of it.
The military also doesn't seem to think it's a hoax. (PDF)
Simple math/logic says it pretty well:
- Earth's volume is finite.
- Oil is only found in the upper crust, which makes up a small portion of that overall volume.
- Oil is produced more slowly than we use it, and our consumption rate is increasing.
Therefore, we can be expected to run out at some point in time, unless we reduce or stop consumption of it.
We'll of course reach a point of diminishing returns
long before sucking all the wells dry, where it will only continue to become more and more expensive to extract the remaining deposits - that point of diminishing returns is the "peak."
The easy deposits have been found and exploited...because they're the easy ones to find.
The ones that are left, like the shale deposits, are more expensive to extract the oil from.
Much like helium: Right now, we dig it out of the ground - it's mainly found with natural gas deposits. Once released into the atmosphere, it rises to the very top, where random thermal collisions allow the atoms to bleed off into space. So there's also a "peak helium" problem, though it tends not to get much attention; most people only know helium as something that's useful for party balloons and blimps.
Now, we could send spacecraft out there to round up those atoms and bring back some helium. It'll be ludicrously expensive though, likely trillions of dollars and several decades to get enough to fill a single small balloon.
Or we can use fractional distillation to get it out of the atmosphere. Problem is, it's extremely rare in the atmosphere, because of its tendency to escape from the planet. So again, it would be extremely expensive.
