PDA's and getting them to run completely out of battery
edjam
1,196
Right, I have this Sony Clie and part of the solution to a problem I have is that I have to totally drain the battery. Thing is, how exactly do I do this quickly? I mean, I can't use it constantly, I am not charging or anything and I can't see where to totally disable automatic turn off so I can just leave it on. Any one got any suggestions?
hoihtah
5,183
i think there's a software that does this for you.
that'll drain out the battery.
look for it in tucows or google for it.
edjam
1,196
Thanks for your help, though the problem is that I am not able to Hotsync...so any solution would really have to be on the PDA itself already. Thanks anyway though.
cavingjan
1,719
Can you transfer something to a MS and transfer it from there to the PDA? Won't a simple hard reset work?
edjam
1,196
No way to transfer to MS, I would have thought a hard reset should do too, in fact, I'll probably try that.
