pctv Pro drivers and dscaler
luv2liv
awhile back there was a sale at compusa $50 for the pctv Pro with the $50 rebate.
n then there was a huge thread on the card and the drivers and dscaler.
the thread isnt there anymore. n any help from you would be greatly appreciated.
for instant, which driver r u using n where can i get it from? isnt it version 5 from pinnacle themselve?
also, which tuner do i select under dscaler?
TIA
I'm running a stock PCTV with the btwincap sourceforge drivers (google it, easy to find). The latest version of Dscaler automatically recognized the tuner (Philips something or another). If you want, you can also use the stock pinnacle drivers (dig them up on pinnacle's horrid website). Note that you'll need the pinnacle drivers to use the pinnacle viewing software (a bit more user friendly, but much less powerful than Dscaler).
would u mind sending me your dscaler's ini file?
the settings i have refuses to work. it would lock my winxp pro instantly!!
i didnt even know thats possible since my xp is so stable
thank you
