PCs not wanting to connect over network
BirdDad
I have two computers both on the same access point.
One sees the other but when I dblclick on it it says it is not found, the other PC doesn't see the other one at all.
Network discovery is on on both
Private network on both
IPv6 is disabled on both of them and I want to keep it that way.
Thanks
Discovery On is good, but it just the first step in configuring Network Sharing.
Windows File Sharing Shorter.
Make sure that the Software Firewall on each computer allows free local traffic. If you use 3rd party Firewall On, Vista/XP Native Firewall should be Off, and the active Firewall has to adjusted to your Network IP numbers on what is some time called the Trusted Zone (consult your 3rd Party Firewall instructions.
General example, http://www.ezlan.net/faq#trusted
Windows 7 Work Network, http://www.onecomputerguy.com/windows7/windows7_sharing.htm
Vista File and Printer Sharing (applies for Win 7 too)
- http://technet.microsoft.com/en-us/library/bb727037.aspx
When done hard reboot all Network's computers and the Router.
If you have Permission and Security issues with Vista/Win7, check the following settings.
Point to the a Folder that meant to to be share. Right click and choose properties.
In the properties
Click on the Security tab shown in the pic bellow to the right) and check that the users and their permission (shown in the pic bellow center and left) are correctly configured. Then do the same to the Permission tab.
This screen shot is from Win 7, Vista's menus are similar.
http://www.ezlan.net/Win7/Permission-Security.jpg
In both the Security panel, and the Permission panel you have to highlight each User/Group and examine that the Permission Controls are checked correctly.
When everything is OK, Reboot the Network (Router, and computer).
* Note . The Groups and Users shown in the screen-shoot are just an example. Your list will look the way your system is configured.
**Note . All users that are allowed to share need to have account onall the computers that they are allowed to connect to.
Everyone is an account, it means a group of all of the users that already have an account and been established as users. It is available to avoid the need of configuring permission to each on its own, it does not mean
Everyone that feel that they would like to login.
