PCMCIA modem in laptop not dialing..... HELP
CyBOrz PaCe
217
Can anybody help me.
I have never messed with laptops before.
My friend got a laptop. An older Compaq LTE5300. It has a US Robotics XJ-CC5560 PCMCIA card Modem. Fooling around with this for a couple of days now I have also found out it is running Cirrus Logic PCIC compatible PCMCIA controller (if that matters at all).
The problem is that whenever I try to get the modem to dial out. Using AOL, using a Dial Up connection I set up or using the accessory "phone dialer" I just hear the dial tone. The modem never dials. Just the dial tone until the operator says "if you'ld like to make a call.... blah, blah".
When I go to modem properties, diagnostics, more info... I get a list of commands and responses like I've never seen. It starts with the normal AT commands I usually see (not that I know what they do). Then the list goes on. I see things like "Last dialed#", "Normal mode (~Z0)", "strike a key when ready", "stored phone #0: #1: #2: #3", and on and on. There is a stuff in between all of these.
I don't know if the settings / commands above make a difference or not.
The other thing I believe may be an issue but I am not sure. In device manager - Modem is fine, PCMCIA Socket lists "Cirrus Logic PCIC compatible PCMCIA controller" and all is ok. BUT under the heading "OTHER DEVICES" PCMCIA Card Services is listed and there are no drivers installed.
Help me please..... I don't have any clue where to go from here. If there is more info you need, please let me know.
CyBOrz
reality bites
95
How about if you use hyperterminal to dial out? I just want to see if the modem will dial at all outside of AOL and dial-up networking. If it works under hyperterminal then your problem is all software related, if it will not work then you may have a driver or hardware issue.
CyBOrz PaCe
217
Hyperterminal?
Is that what I get by going
start> progams> accessories> communications> phone dialer? If so, I tried that and same result. Just the dial tone.... then the operator, no dialing.
CyBOrz
reality bites
95
hyperterminal should be installed by default on every version of windows.
Try - Start - Run - then type in hypertrm.exe and press enter
give it same made up name for the session and enter a phone number of some sorts for it to dial.
If you get the same thing then I would remove the modem and delete it from the device manager, reboot and re install it making sure to use new drivers.
The issue with the PCMCIA card controller showing up as a known and as a unknown device may be significant here.
I think the Compaq LTE has a Cirrus Logic PCIC compatible and a Card bus compatable controller inside. You might want to check Compaqs web page for a PCMCIA card controller driver.
CyBOrz PaCe
217
Thanks. I will try the hyperterminal.
I have been all over ms support and compaq support pages. But can't seem to find any pertinent info. The laptop is several years old. I will research further for new drivers. I have already uninstalled the modem and pcmcia drivers and reinstalled. I just allowed windows to use the drivers it found to reinstall.
At this point I do not have any drivers or driver disk for the US Robotics XJ-CC5560 PCMCIA card Modem. I found some links on the net but they were all old and led to removed pages.
CyBOrz
CyBOrz PaCe
217
RB, you da man!!
I will check em out when I get home. I am hoping that will work. I hope I can find the drivers for the PCMCIA Card Services that is listed under Other devices in device manager.
Your help is appreciated!
CyBOrz
CyBOrz PaCe
217
UPDATE
Nothing Reality. I downloaded the latest drivers and installed. I even ran hyperterminal. Same thing. Just dial tone... no dialing. Then operator "if you'ld like to make a call".
I am going to see if I can solve the "other devices" problem.
CyBOrz
CyBOrz PaCe
217
It's windows 95.
I am at compaq's site searcing for some drivers to install for the PCMCIA Card Services that is listed as "other device" and says it has no drivers loaded.
Should I be looking there or at Cirrus???
CyBOrz
CyBOrz PaCe
217
Like I said, I am at Compaq's site.
Does this sound like something I might try: (it takes five floppies, ugh)
Supplemental Programs
Version 2.00 A - 25 Apr 1996
This softpaq contains 5 diskettes with the following utilities:
- .INF FILES FOR INSTALLATION
- COMPAQ INFORMATION CENTER
- PCMCIA REAL MODE DRIVERS; MOUSE DRIVER
- CIRRUS DRIVERS
- WINDOWS 95 DRIVERS
SUPPORTED OPERATING SYSTEM: Microsoft Windows 95, Microsoft Windows 98
I downloaded the softpaq. I would need to unzip it onto 5 disks and load it on the Laptop.
CyBOrz
