- Oct 9, 1999
- 1,316
- 0
- 0
Can anyone explain the draw on a system you get from using a pcmcia usb adapter? I mean, I know that you can only have X usb devices hooked up and then you will start running into problems, but what about if you have some of the usb devices plugged into a pcmcia card usb adapter? Is it the same? Or does using the pcmcia card gain me anything? Thanks,
j
j
