PCIE power adapters for x1950xt?
dahuang1
62
I just got my x1950xt in and I don't have a 6 pin power for the card. I saw an adapter on newegg here - but it's not clear if you should remove the central bottom pin or not - any ideas for this card? And all that said - am I dreaming that my 380 antec supply will be up to the task? The silent PSU review website said the cards don't really need all that power as advertised?
Geoff
Uhtrinity
2,263
202
I have an older 600Watt single 12v rail power supply. I just made an adapter out of an old ATX plug. 3 pins on one side are grounds, the other 3 pins are +12v. I believe the spec allows for up to one of those pins on either side to be disconnected, but it shouldn't matter if they aren't. Mine works fine with a single 12v rail connected to all 3 12v points.
Uhtrinity
2,263
202
The 12v connections are against the PC board and the Ground connections are farthest from the board.
When I made mine I cut a 6 pin segment off the end of a 20 pin ATX connector, due to the keying I had to shave two corner off of one pin, makes a perfect fit and gives you a keyed connection. I used a standard molex 4 pin female connector, and ran the yellow (12v wire to the 3 12v connections on my new 6 pin plug. And ran the 5v and 12v grounds to the 3 ground connections on the 6 pin plug. Also, since this plug has the potential to draw a lot of current be sure to solder all of your connections.
I have read other posts where people had made their own plugs on multi rail power supplies using two molex connectors, and running different rails to different 12v connections on the 6 pin plug. All grounds should be common.
Hope that makes sense, and be aware if you try to make your own plug you might fry your card, motherboard, and / or powersupply.
edit - Also make sure your powersupply can handle the load. Mine supplies 20+ amps on the 12v rail and runs fine.
