- Jan 29, 2010
- 702
- 6
- 81
Hey guys,
Just got a new XFX 280x to replace my old 5870. It needs an 8-pin and a 6-pin. I thought my PSU came with an 8-pin cable, but it turns out it does not. It's an Antec Neo HE 550 watt, with 2 6-pin PCIe connectors. The XFX booklet specifically says not to use an adapter to combine two 6-pins into an eight (in any case, if I did I'd also have to use the also-included adapter XFX gave me to turn 2 4-pin molex into a 6-pin PCIe, and if the one is taboo I'm sure the other is too).
It's a modular PSU. Am I going to be able to find an 8-pin PCIe cable to solve this problem? Or is the PSU lacking additional rails, and I need to replace it?
Here's the psu: http://www.newegg.com/Product/Produc...82E16817103941
And in case the link doesn't work, specs from newegg:
Type: ATX12V
Maximum Power: 550W
Main Connector: 20+4Pin
+12V Rails: 3
PCI-Express Connector: 2 x 6-Pin
Power Good Signal: 100-500ms
Hold-up Time: 20ms at full load
Over Voltage Protection:
+5V trip point < +6.5V
+3.3V trip point < +4.1V
+12V trip point < +14.3V
Input Voltage: 100 - 240 V
Input Frequency Range: 47 - 63 Hz
Input Current:
9A @ 115V, 4.5A @ 230V
Output:
+3.3V@24A, +5V@20A, +12V1@18A, +12V2@18A, +12V3@18A, -12V@0.8A, +5VSB@2.5A
Features:
Connectors
1 x Main connector (20+4 pin)
2 x 12V (P4)
6 x peripheral
4 x SATA
1 x Floppy
2 x PCI-E
Thanks guys. Love to hook this baby up and go crazy tonight.
EDIT: Just to be clear, the PSU is completely modular, except the 20-pin mobo cable. That in mind, I would just need something like this, right? http://www.frozencpu.com/products/8...B-PCIE8-EXT.html?tl=g11c413&id=rhnaYybH#blank
Edit 2: added a picture
https://www.dropbox.com/s/80l0zprnns4yhnp/antec psu.jpg?m=
Type: ATX12V
Maximum Power: 550W
+12V Rails: 3
Input Current:
Output:
Features:
Connectors
2 x 12V (P4)
6 x peripheral
4 x SATA
1 x Floppy
2 x PCI-E
