PCIe card $200 or less
Originally posted by: SuperTyphoon
if you can find a 6800 or x800 for the same price get it.
EDIT: duh, ther is no pci-e for 6800
i think there is....!! im pretty sure i saw a PCI-e 6800 Vanilla
Yep, X800 or 6600GT. You have a nice system, though, so if you want to game at high res with AA, the XL is definitely worth the extra ~$80-100. 50% higher price for more than 50% greater performance at high res (thanks to double the memory, double the memory bandwidth, and lots more fillrate).
there is a vanilla 6800 pcie, they just made it from a different chip then the ones used on the agp version, the only thing is the 4 pipes cannot be unlocked on the pcie version
though if you can afford the x800 xl at 269, its well worth it, a lot more card
theres one on newegg for $190...n theres no need of 256mb, just a waste of money spending $250 to get 256mb on the Vanilla...might as well get the Pro or XL!!
Originally posted by: Insomniak
Originally posted by: coomar
you mean like this one:
SAPPHIRE 100109 Radeon X800 128MB 256-bit GDDR3 PCI-Express x16 Video Card - OEM ---------------------->189
http://www.newegg.com/product/Product.a...128MB+GDDR3+PCI-Express+x16+Video+Card
that would be the best card under 200 dollars, 256 meg and 256 bit interface
It's 128 meg, but yes, still a good price.
EDIT: Ah - it's OEM. That would be why.
It may have 128 meg but at least its on a 256 bit memory bus.
Even the 9500's and 9700's had 256.
I'd take the x800, 12 pipes aswell.
Good deal.
Good deal.
I don't see why a 256bit memory interface matters if the card gets outperformed. I'll put my 128bit 6600GT up against a 256bit 9700Pro any day.
Yes, the extra pipes are nice and that's a very good price, so yes, get the card I say. The only thing that would matter is if they want warranty coverage, which you generally don't get OEM - but if that's not an issue have at.
The alternative of course is to get a 6600GT and save about 40 bucks, but if 200 is your budget, go ahead with the X800.
