- Nov 15, 2010
- 8,115
- 0
- 71
I have to agree. SLI/CF isn't that bus bandwidth intensive. If PCIe 3.0 was that beneficial, you'd see some big differences even in single card tests.something is definitely wrong with those results.
Eh, it might make sense that the GTX680 at those resolutions can saturate a PCIe 2.0 8x link, and than the double bandwidth of PCIe 3.0 would increase performance.
Not necessarily. There is only X amount of bandwidth available between processor and PCIe 2.0 cards (and potentially 2X on PCIe 3). If I single 680 can utilize .5X, you're not going to see any difference going from 2.0 to 3.0, but add in 4, and suddenly you want 2X where 2.0 can only provide X.
you sure about that?It doesn't work that way but the opposite, the higher the resolution the less PCI bandwidth is needed so the biggest differences in performance with differing PCI-E bandwitdh are with low resolutions.
UPDATE: Actually the amount of PCI-E bandwidth needed is the same regardless of the resolution, but because the framerates go down so do performance differences between differing PCI-E specs.
"However, in this weeks evaluation testing at x8/x8 and x16/x16, we see that having both video cards at x8 does somewhat impact performance, but only at the higher 5760x1200 Eyefinity/NV Surround resolution."
http://hardocp.com/article/2010/08/23/gtx_480_sli_pcie_bandwidth_perf_x16x16_vs_x8x8/3
anandtech said:For any given game the amount of data sent per frame is largely constant regardless of resolution, so weve opted to test everything at 1680x1050. At the higher framerates this resolution offers on our 7970, this should generate more PCie traffic than higher, more GPU limited resolutions, and make the impact of different amounts of PCIe bandwidth more obvious.
He has two videos up, one shows 2.0 with 4 cards getting around 70 fps, he regedits for 3.0, reboots, and comes back getting 130 fps at the same location.
http://www.youtube.com/watch?v=S0-xcxAvu54
Would be nice to know what fps he gets with a single card, but it looks like 4 card scaling at PCI-E 2.0 is utter crap, with that kind of scaling even my cards are faster. It looks like an issue with SLI, maybe not enough bridge bandwidth but that would mean it couldn't be solved with a driver update.
well would 16x/8x/8x/8x at 3.0 really only perform like 8x/4x/4x/4x when running 2.0?
