- Oct 30, 2004
- 11,442
- 32
- 91
I've wondered whether the PCI-slot blower fans are really effective or actually counterproductive.
If the idea is to have a flow of cool air from the lower front and lower side of the case to the upper rear of the case, then wouldn't a PCI slow blower work against that by sucking cool air out of the lower rear before it can make its way to the GPU and CPU?
I have a Chieftec Matrix (standard ATX case) with five fan locations--two 80 mm in the rear near the CPU area, two 80 mm fans in the lower front, and one side fan (80 mm) that seems a little low (though it might actually be in a good position for GPU cooling).
How would a PCI slot blower help?
I'm thinking about adding a cooler to the uppermost 5.25 drive bay what would pick up stagnant air from the top of the case and exhause it out the front. (This one. ) I might also use a drill press at work to cut out an 89 mm hole in the upper side area for a 92 mm fan. Not sure if that one should blow out (to exhaust hot air from the upper region) or in. I could also place it at middle height and have it blow in.
Instead of a PCI slot blower that blows air out the back at the bottom of the case, might it actually make more sense to have a blower that sucks air inwards and blows it up onto the GPU? Is there such a device?
