I'm building a server, and would like to eventually put a RAID controller in it. The controller I've been looking at is a 32-bit, 66Mhz card (so the datasheet says). I've never been concerned with anything other than 32-bit, 33Mhz PCI slots. This started my questions about PCI below.
1. What are the differences (mb requirements) between a PCI slot running at 66Mhz and one running at 33Mhz?
2. Can a 66Mhz slot run 33Mhz cards?
2a. If #2 is "yes", does that apply to both 32-bit and 64-bit slots?
3. Can a 64-bit slot run 32-bit cards?
Thank you!
Thank you!
