PCI or AGP for second monitor
gohmdoree
9
Hi, I just ordered another monitor for my computer. I have a Geforce 3 AGP card with 64 MB. I was thinking of just getting a PCI card that was comparable. Someone suggested to not bother and just get a dual board video card. What do you guys recommend?
tbates757
1,235
What are you using it for? Probably go with a dual-head AGP video card and ditch the GF3
gohmdoree
9
I don't really much do too much gaming. My main purpose will be for doing graphic design and programming. I wanted to get more real estate.
Any suggestions on chipsets or brands?
Chaotic42
34,546
1,709
If you don't game, get a Matrox G550 dual head. It's a very sweet card. I'd love to have it's quality and my Radeon's graphics power all in one card.
Shooters
3,100
Just buy a PCI card. You can probably find one for pretty cheap in the FS/FT forums. I ran an old PCI Voodoo3 with my GeForce3 and didn't have any problems.
Sheriff
1,182
I use the 2 card method (best of both worlds IMO) Good combos with the ATI 9700 I use are, Matrox (G200) and 3DFX (V5500). The V5500 only uses 32MB of it's power but I like the 2D graphs
dmw16
7,608
I would say either way would be fine. If you can get a PCI card for cheap then go that way, or if you wanted to possibly upgrade you could pick up something like a radeon w/ a db15 and dvi connector on it and convert the dvi connection.
-doug
Jan 31, 2002
40,819
There's an nVidia Quadro4 NVS200 for sale on the boards. With a cable upgrade, it can handle Dual-DVI. PM me if you want a direct link. No, it's not mine - I figured I'd just point him in the right direction. :)
- M4H
