Originally posted by: Lord Evermore
Originally posted by: Googer
Originally posted by: Tarrant64
I don't know if there are any, but do you not have anymore regular PCI slots?
Yes, but PCI slots are becoming a rariity and two hard drives will flood my PCI bus leaving no bandwith for other devices.
Both hard drives, continuously streaming sequential data from the fast parts of the platters, simultaneously, might hit the maximum realistic throughput of PCI, but you shouldn't actually see THAT much of a bandwidth limitation. How many other devices do you have on the PCI slot? If you're using integrated audio and networking, those don't use PCI unless you have an pretty old board.
PCI slots are still far from "rare" (even microATX boards still have a couple) and won't be for a while, at least a while after your IDE drives aren't really of any value.
If you get a rare PCIe IDE controller, you'll just end up with a controller that isn't of any value later anyway, since you aren't likely to be getting any more IDE drives.
Development began to shift to SATA controllers before PCIe was out, which means there's very little reason anybody would be developing any sort of IDE controller anymore. It becomes one of those things that people only make because one small niche like businesses with legacy applications require the older interface on a newer system, which means it's expensive because they only sell a few.
