Hi,
I'm looking to get a new mobo but I'm unsure on how PCI-E, in crossfire mode, will be effected by the PCI-E slot speeds.
I believe that I want both cards, in crossfire, to run at x8 if the first PCI-E slot rates at x16? I'm assuming this since the mobo has a PCI-E slot that is x16 so when I put in a second card it will split the speeds between both, which result in x8 speeds for both?
The mobo specs say - 2 x PCI Express 2.0 x16 (green @ x16 mode, orange @ x4 mode).
I have no idea how the orange@ x4 will affect the crossfire speeds. If I add a second card does it mean they will both run at x4? I know for ram that if you get a high and low speed ram the high speed ram will operate at the speeds of the slower one. Is this the same for PCI-E?
Thanks
~G
Thanks
~G
