- Mar 8, 2014
- 12
- 0
- 61
I see that risers can be purchased for fairly little $$ and can be up to about 15" - they are available in all 4 speeds.
I also see external pci-e expansion cases which are a pci-e card with a port on the back, cable, and external case. These are like $400-$1,000 for a single port!
Since the slot delivers everything the card needs to run (except very power hungry graphics & co-processor cards), Is there a way to extend the slot with a cable that extends outside of the case and maybe into an external case where a slot is mounted (for cards that need a minimum of power)? I know EMI is an issue, so a shielded cable is necessary.
Is this doable and if not, what is the best way to extend a pci-e slot outside a case by maybe 1 meter?
