I recently bought a refurbed Lenovo M57P which I'd like to turn into an HTPC. The chassis is a pretty small/compact mini-case and it has a 90 degree riser card to accept a GPU, however the socket on the riser card does not match the GPU connector. The socket on the motherboard, that the riser card plugs into, DOES match the GPU but I can't plug the GPU into that slot due to physical orientation limitations.
What gives with the riser card? Why would the socket on the card be different than the socket on the MB? Do I have any options or am I SOL?
