PCI-E power requirements?
Pabby
Hi, I'm pretty experienced with PC hardware and I'm thinking about upgrading to an SLI setup soon. I'm interested to know what the power requirements are for PCI-Express cards?
I'm a little confused about PSU's. I've been seeing PSU's about with 24-pin main connectors instead of the usual 20-pin, will I need one of these? And what about the cards themselves? how many connectors does each 6600GT take and what kind? I've also seen special PCI-E x16 connectors which i assume go in to the x16 card, how many will i need for each card and will they then require any additional connectors?
Basically what connectors should be on the PSU I need?
EDIT: Corrected to PCI-E not PCI-X (I'm a silly monkey today)
First off, its PCI-E, not PCI-X. 🙂
You will need a 24pin PSU, if you get a PCI-E motherboard. Unless you want to fool with a 20 to 24 pin adapter. If you are buying new, I would just get a native PCI-E PSU, less cables, and it will have a PCI-E video card plug.
If I am not mistaken, the PCI-E 6600GT's do not additional power. So you wont need to plug in any thing into them.
if your thinking about sli, you'll want a mobo with pci-e connectors (6-pin) if your going to be using a 6800gt/6800ultra, their are adaptors from molem though i think
