PCI-E card to replace 9800Pro AGP
osage
5,686
I finally went to a PCI-E mobo so I need to replace my 9800pro AGP.
I was considering a used 7300gs from here on the FS forum, so I asked for some help here in the Video forum.
thanks to the suggestions from them and the links provided I can see that was not going to be a good move.
I do appreciate the advice and suggestions, it prob saved me from making a bad choice.
osage
5,686
so will I need to go to 7300GT to get about the same performance, or will I need to go to something else ?
budget will be tight if I change to a new mobo that has PCI-E that why I was looking at 7300gs
osage
5,686
very nice chart, that's what I needed.
thanks for the link.:)
X700 PCI-E seems to be about what I need
AllWhacked
236
Don't get the X700. At best the X700 is equal to your 9800 Pro and at worst it is slower. If you want to do a comparison, goto Toms Hardware VGA Chart and compare using a Nvidia 6600GT.
The 6600GT performed equal to or better than a 9800 Pro, whereas the X700 performed equal to or worst.
If you want an upgrade of any noticable differenece I would recommend at least an X800/850XT card or a Nvidia 7600GS/GT.
If you plan to go higher and stick with AGP, there is the X1950PRO, but that sells for anywhere between $250-$300 and the Nvidia 7800GS for around $235 or $176AR. At these prices it might be better off upgrading to PCI-express cuz at least this way, you can keep the card with your next upgrade.
osage
5,686
changing to a PCI-E mobo for sure. I just want to stay about the same performance level with this first PCI-E card.
I will upgrade the card in 3-4 months, just don't have the cash to do mobo/cpu/vid card all at this time.
thanks for your input. I've been out of the loop for a while.
Assimilator1
24,180
528
About 2yrs ago I was looking for a replacement AGP card on a tight budget ,my choices were a 2nd hand Radeon 9700 Pro or a new X700 (which was more).
On comparing many benchmarks I found the X700 was about 0-8% faster than the 9700 Pro ,so I bought a 9700 Pro ,& saved myself about £20 :)
Btw the 9800 Pro is about 10% faster than the 9700 Pro.
How about a 2nd hand card from ebay etc?
osage
5,686
I'll be watching the FS forum for a used card.
I just struck a deal for a PCI-E mobo so I will need to get a card so I can at least test the mobo.
I may have just enough cash to get something in the 6600GT/X700 range...if not I will grab a cheap TC card as a stop-gap measure.
A554SS1N
804
The 7300GT overclock ones with GDDR3 (ones with 500mhz core and 1400Mhz memory for example) would be very nice bargains at the moment, and would be easily faster than a 9800Xt let alone a 9800pro
osage
5,686
would a Radeon X700PRO 256MB keep me in the ballpark with my old 9800 pro ?
looks like it a a bit better in a few benches and a bit slower in others......
postmortemIA
7,721
40
skip X700 pro altogether, can you? it is old tech, no sm 3 support, pretty much 9800 core with 1/2 of mem bus.
CurseTheSky
5,401
I would look into one of the following:
nVidia 6600 series
nVidia 6800 series
nVidia 7600 series
nVidia 7900GS
ATI X800 series
ATI X1600 series
If there's something out of those that fits your budget, it will most likely perform better. The 9800Pro was a solid card in its day. Anything on the lower-number end of the nVidia line really is geared toward general home / office use - stay away if you're planning on gaming.
The 6600 and 6800 series were especially powerful for their day - I believe most of them even beat out some of the 7600 series.
akshayt
Banned
Feb 13, 2004
2,227
7300GT GDD3>Radeon 9800Pro>7300GT DDR2, atleast this is true for a 6600GT which was faster than the 9800pro in most apps
Geforce 6 was average, just as they should have been, nothing spectacular, Radeon 9700Pro and Geforce 8800GTX are spectacular
Assimilator1
24,180
528
lol ,I think you've typo'd their;) ,I don't think my trusty old 9700 Pro would give an 8800 much trouble :D ,or did you mean at their release times?
A554SS1N
Got some links to show that? (re 7300GT vs 9800XT) in a short search I did I couldn't find anything at AT or THG.
osage
5,686
BFG Tech GeForce 7600GT 256MB 128-bit GDDR3 for 79.00 after MIR. this seems to be a killer deal, or is there something better for this amount of money??
Chapbass
3,147
i havent put it on the FS/FT forums yet, but ive got a 6600GT with a zalman HSF for sale! beast of a card, i loved it while i used it (got an 8800GTS for christmas/birthday).
im gonna be home in chicago for a few days for new years, but ill bring the card with me and check my pm's in case we strike a deal or somethin. pm me!
Avalon
7,571
178
That's as good as it gets.
Rockhound1
592
Yep, Avalon said it. That's as good as it gets as far as "bang for your buck." I would recommend you jump on that deal!
postmortemIA
7,721
40
Op, you didn't have to remove your original thread, that is a low blow to ones who tried to help you.
