thats misleading and confusing. Because new boards (eg. the nforce 4 boards) WILL include the 2molex ---> pci-e power adapter [see the gigabyte nforce 4 review at pctstats, the board will come with such an adapter)....if NOT, you still can buy such an adapter for $7 everywhere, eg newegg.
The only difference is that there are two PSU connector-standards now, eg. 20pin (older) and 24Pin (newer)...while this is also (MOSTLY) irrelevant since the new boards should support BOTH standards. The pci-e cards will always have an extra power connector anyway.
Maybe they are referring to the amperes the PSU is able to put out...i dont know...so for the new boards with pci-e board its recommended that you get either a PSU with the new 24Pin standard AND two seperate 12V rails (eg one with 15A.ther rail with 16A or so,).....OR a decent PSU with only one 12V railbut with high ampers, (eg 30A ++).
"not pci-e ready" for me probably means "not enough amps on the 12V rail"...in other words: Its too weak 🙂
