PC100 + PC133 64 SDRAM RAM, will cause problem ?
Spectrum
56
Hello,
I m having a PC100 Siemens 64MB SDRAM. I need to upgrade to 128 RAM but wondering should I get a PC133 PNY 64MB RAM or Kingston PC100 64MB RAM. I would appreciate for any kind of assistance, Thanks !
Regards,
Spectrum
Mears
2,095
From what I hear memory frequency settings are mixable. Of course, you have to run them to the lowest spec'd stick. If I were you I'd go with the Kingston just because I've heard bad things about PNY products and you wouldn't get anything out of it being pc133 because you'd be running it at 100mhz anyways. However, if the PNY is cheaper you might want to go with that instead.
