- Jul 11, 2001
- 40,575
- 10,023
- 136
I've been troubleshooting a problem with these symptoms:
BSOD's in Windows 2000 SP4
160 GB IDE Seagate Barracuda HD suddenly not recognized or writes to it fail after the system warms up. After a BSOD the drive disappears from Windows and isn't seen in the BIOS (Primary/Slave)
I thought the HD was going bad and I got an RMA number from Seagate but swapping the Seagate for a Western Digital 80 GB drive also caused a BSOD. I pressed the power button to turn off the machine and swapped the IDE cable to test if the cable was at fault. If not, I figured the IDE controller was failing.
After swapping the IDE cable the PC will not respond to a press of the power button. It has an Antec Tru430 PSU. I know the PSU is getting power because I swapped the cord that's powering the box I'm typing on and it still wouldn't power on. The system is Beauty in my sig. What could be wrong?
