Mayfriday0529
I'm trying to solve an issue on a system. The system will not POST and the monitor light stays at orange.
Here is the background.
Initially the system would not always POST. You press the power button the fans would spin and the power light in front of the pc would come on. You have to shutdown and press the power again and after a few tries it would come up.
I went ahead and grabbed another Power supply and hooked it up to the motherboard from outside the case. The system started to boot normally every time. So the PSU needs to be replaced. In order to do that I had to remove the motherboard to take the old PSU out and put the new one in.
After putting everything back, I could not get the system to do anything; found out there was a short on the motherboard from one of the screws. Pulled the motherboard out again and place it back in and problem solved. But now with the new PSU installed the damn machine never POST and monitor light stays orange. I disconnected all drives and left only what are necessary items on and still same problem. Not sure what else to do. I even tried the old PSU again, attaching it from outside the case.
The system uses an Asus motherboard with an AMD 3200 processor. Old PSU was 350, new PSU is 450.
Cliffnotes:
Would not always POST.
Hooked different PSU and system worked fine.
Removed Mobo and old PSU and inserted new PSU
System will not POST at all now.
Cliffnotes:
