- Nov 18, 2005
- 28,799
- 359
- 126
This is mighty strange. I've had the problem since getting the keyboard, which was also my first dabble into USB hubs. And I've lived with it (or worked around it) for some time, but now I'm fed up enough to overcome my stubbornness and actually figure out WTH is wrong, I want it to work dammit!
[Background info: The mouse is a Razer DeathAdder)
My Logitech G110 (keyboard) has a USB port, and acts like a hub (since it is daisy-chaining). If I had my mouse plugged into the keyboard, the system wouldn't pass POST. Unplugged, it would boot fine (or plugged into the system itself). However, everything works perfectly fine when the system is actually running... it just doesn't boot in that configuration.
But now, I recently got a desk that has a built-in USB hub. I plug my keyboard into the hub, and my mouse as well. Doesn't pass POST. Same problem in a little different configuration.
One possibility is total power consumption over a single port. But what confuses me about that, is the fact that everything performs in good order when the system is on. If I plug the mouse back in after it passes POST, everything is good to go (including all the LEDs in the keyboard and mouse).
It's most convenient (and better in the long-run) as any other device I'd like connected to the hub requires USB Power, and I'd like more convenient access on the hub.
Oh and another thing - I can also use my Logitech G25 connected to the hub (with the mouse and keyboard)... but that doesn't require any USB power, it shouldn't at least, seeing as it has a power cord.
Is this simply a case where it will never work? I couldn't find anything in BIOS that clicked in my mind as a potential change to solve this issue.
I'm fine with unplugging the mouse every time, if that is what it takes to keep the mouse and keyboard (or dare to ever get something better); I'd rather not do it, if at all possible.
