Malladine
I get an orange light on the motherboard and the cpu fan spins around several times, (indicating the motherboard is definately getting power?) but the system doesn't power up at all.
Earlier today the system rebooted and froze consistently at the starting windows screen. Then I got a windows cannot find ntoskernel error when trying safe mode. I felt heat coming from inside the system and when i touched around to find out which part the heat was coming from it turned out to be one of the small coils of metal on the motherboard. It burned me.
I had been having 3d game issues for a while, pointing a fan at the gpu only seemed a temporary fix, and as it happens this particular coil is sitting very close to agp slot...
I already ordered a replacement motherboard thinking this was the problem but then the system plain stopped powering up as detailed in the first line of this post.
basically i need advice on this to help me decide whether or not to cancel the motherboard order and buy a power supply instead!
Thanks in advance!
If you need further explanation of anything here please ask!
EDIT: oh and during one attempt to power up I heard lots of beeps...in fact it kept beeping til i powered off. Does that mean anything beyond that it's broken?
Thanks in advance!
