Question PC turns on and then turns off after a few seconds
OrangePineappleSoda
16
I tried with my old motherboard. Plugged in the psu into the motherboard, but with no cpu, ram, cooler, case etc. It did not turn on at all, trying to power it on with a screwdriver did nothing. I'll try with the new motherboard when I have time.
Reactions: rebbalancaster
BoomerD
62,091
10,278
IF you pull the CPU, please post pics of the motherboard socket pins and the back of the CPU.
I still lean towards something shorting/grounding the motherboard to the case. Obviously, it it does this when you do an out-of-case build on non-conductive cardboard...then I'm way off base.
OrangePineappleSoda
16
Unfortunately the problem came back. When I connect a power button to the front panel header on the motherboard, the same problem happens (computer turns on and then turns off after a few seconds). When I disconnect the power button and turn the computer on with a screwdriver, the computer works. I'll try again later with a new power button.
mikeymikec
16,929
7,882
If your case has a reset button, you could use that as your power button for testing.
Reactions: OrangePineappleSoda
