Startled Armadillo
23
Does anybody know where I could find a relatively inexpensive subwoofer for my PC? I have a Dell AS501 soundbar, which has a sub-out RCA type connection, but I can't find anywhere that I can purchase just a subwoofer to connect to the output. Dell doesn't make such a subwoofer, so does anyoen have any suggestions?
alcoholbob
6,390
470
What's your budget?
If you are willing to spend around $130-140, goto partsexpress.com and buy the Dayton 10" or 12" sub.
There aren't really any component subs cheaper than this on the market (new). If this is beyond your budget, you could always try the used market. I'm not sure what exactly you could find (if any) in the PC market to help you, but if anything (like the Klipsch SWS, at $250+), I'd doubt it would be cheaper than what I suggested.
sep
2,553
How do you like your sound bar?
