Muse
I'm running Windows 2000 with a Hercules Game Theater XP 6.1 soundcard that I've had around 3 years. The card's hooked up via coaxial cable digital connection to my Kenwood VR-6070 AV receiver. The last 2 weeks or so I've noticed some background noise in the signal - IOW, when I mute a PC sound-producing application, I hear some noise reminiscent of a noisy amplifier. However, the problem is only with the PC sound, not other stuff I have plugged into the receiver. That's not why I'm posting, although that is an issue I figure should be dealt with - that noise is annoying.
The reason I'm posting is that all sound from the PC has gone mute. I see the equalizer bars going up and down in the GTXP control panel, but I hear nothing from my receiver. It happened while I was watching a TV program with my TV card, so I thought it was the transmission - the sound suddenly came back. But then it happened again a few minutes later, and I checked my other soundcard output (MP3, wav, midi), and it's all silent - even that background noise is gone! Other receiver functions work fine, just not sound from the PC. I figure I can remove and reinstall the soundcard, replace the cable between the soundcard's breakout box and the receiver, and see if that helps. Could it just be that the "soundcard died?" TIA.
