Hi,
I'm having a very annoying problem. Whenever I use the keyboard in any way my PC seems to slowdown as if its stuck in treacle. The main area I noticed it is sound, for example right now I have winamp on and as I am typing this its as its going in a kind of slow motion. When I stop typing it goes back to normal. Its happening when I play games aswell that use the keyboard and it makes them hard to play....however if I am using a gamepad there are no problems, I've been playing Toca Race Driver 2 for the past 2 days and had no such slowdown, but today I tested it and pressed keys during a race and the slowdown started.
My Specs are Windows XP Pro, XP2800+ Barton (running at 45 idle, no higher than 55 load), 1Gig of DDR333, an 80Gb Maxtor HDD, an Audio Extreme 5.1 Sound card (from dabs value), a Microsoft Internet Keyboard, Microsoft Wireless Optical Mouse 2.0 and an FX5700 Ultra 128Mb w/ 56.72 drivers.
If it makes any difference I have 3 IDE Devices, the HDD and the DVD Drive (Creative 12x) are on IDE 1 Primary and Secondary Respectively and the CD-RW (LG 52x32x52) is on the secondary by itself.
Other devices I have connected are a Cannon i250 and my camera cable through a 4 port USB 1.1 Hub, along with a Saitek P2500, a Logitech Cordless Freedom (2.4GHz) Joystick and the Microsoft Wireless Optical Mouse 2.0 - all 3 of which are directly into the motherboard through USB 2.0 ports.
I would appreciate any help on this. Thanks.
Darkhound
EDIT: btw things I have tried are:
Disconnecting the Pad and reinstalling it
Disconnecting the USB Hub
Removing the keyboard in device manager and restarting
Darkhound
