PC slow after renewing thermal paste
alzan
3,860
I wouldn't think re-applying thermal paste would affect OS operation. I'm assuming all ran properly before pasting.
Does the laptop freeze up, bluescreen or shutdown suddenly? Is it possible the CPU heatsink/fan connector didn't get hooked back in to the motherboard. Also possible that not all of the screws for the heatsink/fan assembly got set and tightened down.
Just curious, why did you re-apply the paste? The paste from the factory normally lasts the life of the laptop unless you swap out the CPU.
Ketchup
14,559
248
First order of business here would be to get a program like CPUID HWMonitor to tell you what your CPU core temps are.
Evenodd
30
@alzan
No the laptop didn't freeze, get a blue screen or shutdown by itself. I wanted to reapply the paste because I wanted experience and I recently learned that you should always renew the thermal pasting every 9-12 months. The thermal paste was also solid and dry before I added some fresh paste, and I heard that was bad. :(
@ketchup
HWMonitor
Ketchup
14,559
248
OK, you temps look fine. But thermal paste will last years with no re-apply needed. Basically, if you never break the bond, you never need to re-apply.
Are those temps while you are experiencing the slowness?
Slowness can come from all sorts of things: viruses, disc fragmentation, low memory. But I don't think it is heat unless that screenshot wasn't during a time of slowness.
What model laptop do you have?
I would start with a scan by MalwareBytes Antimalware and see if it finds anything that needs to be removed.
Evenodd
30
Thanks for the information!
Yes these are the temps right now, I just took that screenshot. The model of my laptop is a Sony VAIO VPC-F11LFX/B.
MalwareBytes didn't catch anything.
Ketchup
14,559
248
OK, look at the Windows information page (Control Panel/System) and make sure that, if you removed the RAM sticks, your computer is still recognizing all the RAM in the laptop after re-assembly. Looks like it comes with 4 GB.
Evenodd
30
Yeah, I did remove the ram before I put the paste on.
It says "Installed Memory (RAM): 2.00 GB".
I'll shut down and reseat the ram.
Evenodd
30
Awesome!
I checked back and it said "Installed Memory (RAM): 4.00 GB". My laptop is as fast as it used to be and it's all thanks to you, ketchup!
Nice job!
