PC restarts for no reason Help! :(
arele
here is my problem
my pc restarts at any movement for no reason... this happened 2 times in 5-6 hrs... wat i was doing for the firsts time was juz writing an email from mozilla... and the second time when my pc rebooted when i was searching somethin in kazaa...
this has never been a problem with me... i donno suddenly wat happens and my pc juz goes to the boot screen...
as the pc restart its again normal.. it comes up with the scan disk while restarting with no errors and again it works fine for some time and again suddenly it reboots.. after restarting windows says " system has recovered from seriuous error do u want to send the error report" as i send the error report they say its caused due to installation of some drivers and bla bla bla...
my recently installed softwares and drivers include..
Shareaza_2.1.0.0 (i uninstalled it within some hrs..as i didnt like it)
nVidia Display Drivers 66.93_win2kxp_english (latest) (its currently running fine with my graphic card GForce 4 MX 440 128MB)
Messenger Plus for MSN Messenger v3.25 (MsgPlus-325)
im running Windows XP with sp2
my cpu temperatures and all are fine..
how much RAM do you have? sometimes with programs that eats a lot of ram it cause the comp to restart auto.
Restarting is indicative of two things: heat, or a blue screen of death (usually a hardware or driver problem). Running out of memory may generate an error message, but it should never cause a restart.
Trying Rolling back on the Video Drivers.
If your running a Sata Drive, there's a patch on microsoft's website that fixes Rebooting with SP2.
Spyware maybe?
I once had this problem and it turned out my power supply was going out. Found it by accident but a new one solved that problem.
Yes I would agree with the above posts, either the power supply isn't providing enough power to your hardware, or your cpu could be over heated. Do you overclock at all? The next time it reboots, boot into the BIOS and check your hardware temps.
i hav tried running all types of scans for viruses and malwares by Ad-Aware SE Pro 1.05, and ESET NOD32 Antivirus.. also registry scans by System Mechanic 5 Pro.. but in vain.. as i said before my temperatures are normal and i havent overclocked my machine yet... i already use an UPS with 25min.. backup..
Spyware maybe?
im not sure if i have a SATA so where should i verify that..
Originally posted by: MrChad
Do you have a .dmp file in your C:\Windows\Minidump folder?
ya i do hav those files in Minidump folder. there are 2 files...
How large are they? Send them to me and I can analyze them.
where should i send them there is no attachment option here i can see.. im new to this forums so plz..
It appears as though the culprit is vsdatant.sys, which is a ZoneAlarm file. Make sure that you are running version 5.1 or higher. ZoneAlarm may be conflicting with some other piece of software on your machine.
IM using the latest version of ZoneAlarm Pro which is 5.5.062. other softwares i use are ESET NOD32, Ad-Aware SE Pro 1.05..
Is the built-in Windows firewall disabled? I'm not sure what to tell you. You might try contacting ZoneLabs support to see if they have any ideas.
YES the built in firewall is disabled...
Odd...I've never heard anything like this from ZoneAlarm before.
Share your desktop with NetMeeting to another machine and control it from there for a few hours. If you can't repro, it's your mobo.
after a lots of time on my PC i have come down to one thing..
the PC reboots when i disable and again enable my LAN Connection...
i have a onboard LAN and a D-Link LAN Card but only 1 internet connection so i use
either of the both LAN's but the problem here is the PC reboots only when i disable and enable the LAN which is connected with my cablenet wire... the pc dosent reboot if i disable and enable the LAN which is not connected to the Cablenet wire...
Why this happens someone plz help...this was never before..
accoriding to me the problem is with ZoneAlarm i think but its workin with no probs...
