Hey guys, was hoping maybe you could help me out.
I was browsing the internet, looking at a message board I frequent when my PC shut down. It started back up, set itself to the default clock speeds and rebooted again.
Now every time I restart it, it gets up to the words "Memory Test" in the BIOS but hangs at "MEMORY TE".
Here are my hardware specs:
I've also got a DVD drive, a DVD-RW and a floppy. I've been running the processor at 3.2ghz since January with no issues (45C). This whole machine has been running fine since January.
I haven't had more than 5 minutes with the machine to try stuff yet, I will later today. I did try to run with a single piece of RAM, tried both of them seperately, no luck. Also tried unplugging the power from the DVDs and unplugging the system and removing the BIOS battery. I know I should try to clear the CMOS, but I need to find the jumper, I didn't see it with the limited time I had.
I know it's probably the power supply or motherboard. Just wondering if anyone has had any similar experiences or has any hunches. Thanks.
GIGABYTE GA-965P-S3 LGA 775 Intel P965 Express ATX Intel Motherboard
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
FSP Group (Fortron Source) AX400-PN, RoHS, 12cm FAN, version 2.2, 2 SATA, 20+ 4 pin, PCI Express, 400W Power Supply
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-2GBPK
XFX PVT71PUDP3 GeForce 7900GS 256MB GDDR3 PCI Express x16 EXTREME Video Card
