PC PSU for networking equipment?
HKPolice
I have 2 modems, 2 routers & a VOIP device all on the same table in the basement and the AC adapters for them are starting to die off. I've had 2 go within the last 2 years. Since they all use either 12v or 5v DC inputs, I was thinking about hooking them up to a PC PSU instead which has 12v & 5v outputs and a lot less ripple/better regulation than cheap AC adapters.
Would that be an issue? I thought about it a bit more and I know that using a common ground with sensitive audio equipment can cause a feedback loop. What about networking equipment? Would sharing the same power source cause some kind of interference or short over the CAT6 cables?
Thanks in advance!
Conceptually this is doable. Modern PC power supplies - especially the higher efficiency ones - are touchy about needing a certain amount of load on each rail or they won't start. Also watch for voltage drops in your splices and cabling. Ground loop / signal quality wise you should be fine. And of course you'll have to ground the start wire to start the PSU at all.
But this all is a hack, and if you're trying to increase relability, hacks aren't good for that. Consider buying higher-quality replacement AC adaper bricks from hobbyist electronics places (e.g., Adafruit).
