- Feb 14, 2002
- 3
- 0
- 0
Ok I've tried everything in my knowledge to fix this but it's just not working. . . So here is the situation:
I'm running Windows 98 SE, and at any random time my pc reboots (not this pc a diff one.)
Now, one thing I know I can do to make it reboot like that is to open QuakeIII , or try to copy a large file over the network to it. Besides those two it will just reboot at any random time. This just started happening out of no where. . . All I use that PC for is QuakeIII, I didn't change any kinds of settings or install new hardware.
I've tried formatting, while win98 was installing it suddenly rebooted also. Then when it continued and it installed fine. .
I doubt it's overheating because the CPU and System tempature stay around 24C (75F) and from what I've been told by friend's it's a normal tempature + all my fans are working fine (two on CPU w/ heatsink). I've also reset my configuration data and reset to BIOS defaults before and after I took every card out of my system but my video card (Geforce3), and even then , I tried a backup card (Geforce2) and it still crashed. I've taken ram out switched it with other system's ram...nothing works. My hardware monitor says this about the voltage (I dont know if it helps)
VCore Value = 1.79
2.5V Value = .28
3.3V Value = 3.32
5 V Value = 4.91
12 V Value = 12.37
I think it's 250W but I'm not sure. . .
My system specs are
AMD Athlon 800mhz (Slot-A)
512MB PC-133 SDRAM
GeForce3 Ti200 64MB
Apollo KX133 VIA Chipset
SoundBlaster Live! 5.1 X-Gamer
15GB Western Digital HardDrive
DVD-ROM
VCore Value = 1.79
2.5V Value = .28
3.3V Value = 3.32
5 V Value = 4.91
12 V Value = 12.37
My system specs are
512MB PC-133 SDRAM
GeForce3 Ti200 64MB
DVD-ROM
