@ OP - Are you equating "not recommend" with "hate"? Two different things.
I don't think you'll find many people who will claim that they aren't top-notch in terms of quality. The higher end PCP&C units are just much more PSU than the vast majority of people need. If you move lower down the wattage scale, then there are plenty of very good PSUs that are priced more competitively than the PCP&C mid-range ones.
A couple of other reasons why PCP&C PSUs aren't for everyone:
1) They don't offer modular cables on any of their PSUs as far as I know, which is a bit unusual in this day and age.
2) Their PSUs seem to take up more space than a comparable wattage PSU made by other top quality brands. In my case, I wouldn't be able to fit one in my case (I really should have worded that sentence better...). The Silencer 610 is the one I would be in the market for. Unfortunately, due to the atypical dimensions (too long), it simply doesn't fit.
3) Those who value quiet computing appreciate having larger, but lower RPM fans in their PSUs. So I was bit miffed to see that Silencer 750 uses a 80mm fan, especially when 120mm is typical in this segment, with some brands like Enermax and Tt going with even larger, 140mm ones.
