- Nov 15, 2006
- 1,855
- 0
- 0
Got my new computer put together, everything works except it won't detect my USB floppy drive when I go to install windows XP 32 bit. Pess F6 to install RAID drivers and nothing happens.
I have a internal floppy drive but it doesn't use the IDE cable like I thought it did so I have to venture into town and face the swarm to get a new cable. The cable will add too much clutter to the inside of my case (trying to get good airflow) so I can't keep it in there once I get the OS installed.
The floppy drive works because I already made a RAID driver floppy with my laptop. The HD's are both the same and unpartitioned. BIOS set to raid with a RAID 0 configuration made. Using a ASUS M3A79-T Deluxe MoBo and SATA II HD's. I deleted the partitions on the HD's so I know they are plugged in. My USB keyboard is plugged directly into the MoBo same as the USB floppy drive so that works.
So any ideas?
So any ideas?
