PC not recognizing my DVD drive..
A Casual Fitz
4,649
1,018
When I go to My Computer it's just empty where it used to be. I'm in the device manager and it shows an exclamation mark next to the DVD drive's name. I can't seem to fix it.
BoomerD
66,282
14,703
I've had 3 CD/DVD drives die in the past 12 months. Not always the same symptoms...one did exactly the same as yours...not found in "My Computer, but still listed in Device Manager...Tried uninstalling it, reinstalling it...no help. Just doesn't work.
The others still showed in "My Computer," showed in Device Manager, but when you put a disk in them...that never registered...DOA.
I'd try uninstalling/reinstalling the drive...and any drivers if you have them. Otherwise...it may be time for a new drive.
A Casual Fitz
4,649
1,018
The drive still opens and closes fine. I also had VirtualDrive installed and it is showing the same symptoms. This makes me think it's not a physical problem with my DVD drive.
A Casual Fitz
4,649
1,018
I fixed the problem. After more forum searching I saw someone suggest deleting a specific entry in regedit. I did so, restarted and it was magically back in my computer.
BoomerD
66,282
14,703
Hmm...more info on the fix please. I still have the "dead" drives in a box. It'd be nice if I could somehow restore them to use in a secondary computer.
