Is this normal?
Basically if I play a DVD, or Sky TV (I'm in the UK) through my Aego system then that's great.
If I plug in a computer using a 3.5mm jack to 2 phono stereo adaptor and phono leads into the Aego, then the volume, compared to a DVD or Satellite TV is very quiet. I can crank the computer volume up to 100% and the Aego volume right up, so it's passable, but I don't want to do that.
I can make the music (typically ripped in WMP or Winamp) louder using a conversion tool which makes things slightly better.
Would most onboard sound solutions suffer in this way? I am using a mini-itx based computer so low spec - it says 6 channel Realtek ALC655 audio - more on that here
What other options do I have to boost the audio volume from the PC? It has got 1x RCA Composite Video Out, also firewire and USB. I'd like to put L*nux on it at some point, thought I'd better mention that
Thanks
Martin
Thanks
Martin
