Hi,
I recently installed Windows 7 on a new WD 320GB SATA II HDD, and every once in a while it makes a clicking sound, and then the system sounds as if it's shutting down or restarting (I think it may be the HDD spinning down). The system also seems to freeze for a second or two during this time.
I've run WD Data LifeGuard Diagnostics on both my old and my new HDD, and no errors are reported. I've run check disk on the new drive as well.
In my advanced power settings, the HDD is set to turn off after 20 minutes of inactivity, but this problem occurs while the drive is in use, so this is unlikely to be the cause.
I'm probably going to try changing the power cable, and maybe the data cable. After that, I'll be out of ideas.
Any suggestions?
D.
Any suggestions?
D.
