Pghpooh
Wife convinced me to buy a new desk for the pc. The desk has a enclosed area for the computer on the side. There isn't any ventilation other then two openings for cabled to go through.
The internal temp in the area that holds the pc reached 103 degrees f.
I am thinking of doing the following.
Cut a opening in the back of the desk and mount a 120mm fan to exhaust the hot air.
The front door of the desk is adjustable and I will remount the door so when it closes there could be about 1/8 of an inch opening between the door and desk.
I'll connect the fan to a spare 12 volt connector inside the computer so it runs when the pc is turned on.
Any thoughts and suggestions or changes I can make to cool the enclosed area down?
