PC gaming only: 1080p TV vs 1080p monitor
cmdrdredd
27,052
357
Ok, ya that's why I gave you the list of the monitors with their input lag times. I figure it's still important and that panny I listed is still the best one. I don't think 27 ms is that bad when you're considering it's an HDTV. I bet you could find better if you asked around at avsforum too. If your friend gets serious, 1080p monitors aren't that expensive either so he could always get one of those later with low input lag.
Still though, I ask what settings your HDTV was on because some settings have higher input lag than others. If I enable a couple things on my TV, input lag would triple or quadruple.
Like I said if he decides he wants to get competitive he will go with a monitor.
