Question PC gaming on the big LED screen display needs advice on HDMI cable
videopho
4,185
29
The display is a large LED 4k TCL series 8 also serves as my monitor. I need a large screen due to my poor vision (my age LOL)
The graphics card is a RTX 3060 TI with the following output connections supporting.
2x HDMI 2.1 3x DP 1.4a HDCP 2.3
The display only comes with 3 HDMI (I believe 2.0) and one HDMI e-ARC.
For now I am using just a good old HDMI cable for connectivity between the display and the 3060.
I game mostly in 2k or 1080p and gaming in flight sims and some 1st person shooter.
My understanding or assumption is no matter what type of cable(s) I used.
It should not make any difference so long the display does not support DP 1.4a or HDMI 2.1
That being said I would not benefit some of the goodies the 3060 TI has to offer (Ray lighting, G-Sync etc).
Am I wrong or partially correct?
Please entertain me. :)
Leeea
3,799
5,566
Ray lighting will function regardless of cable or display
G-Sync will not function with your display regardless of cable
videopho
4,185
29
Okay here is question.
Would this work (or gives me any benefits such as bandwidth) if I used this cable from the RTX 3060 to my big LED TV display?
Like this RTX-DP -------> HDMI 2.0 (LED TV)
BTW, the cable is unidirectional.
Display Port to HDMI cable
CP5670
5,686
787
The HDMI cable doesn't matter as long as it works and you don't get a black screen. HDMI 2.1 is more picky about cables but your TV probably doesn't support that anyway.
videopho
4,185
29
Just got back from the trip and I learned this very fast.
You got to have both ends in order to benefit from DP1.4, HDR and G-Sync.
Both the monitor and the graphic card have to support these features.
No exceptions!
Hans Gruber
2,536
1,364
The way I see it. Display Port is the HDMI port of PC's. Obviously a little different and a little better depending on the generation of cable and port. For use with a TV. Any HDMI 2.0 certified HDMI cable will work just fine. If you are picky, get a HDMI 2.0 cable that is certified with the hologram sticker. Been there done that. I buy from monoprice and have both the sticker certified and the non certified but works the same HDMI 2.0 cables.
videopho
4,185
29
Well gaming on a big screen has largely one benefit: You get a big screen and that's about it.
That being said I decided to step up my game and I just bought an Asus TUF VG34VQL1B
gaming monitor.
So far so good as I still learn how to adjust the settings of it in which it could be a daunting tasks since there are so many features/benefits that sound like foreign language to me. LOL
Any help I can get from the forum to set this baby straight is highly welcome.
Hans Gruber
2,536
1,364
gaming monitor.
Turn on Freesync on your gaming display unless you decided to spend the big $$ on G-Sync. If you have an Nvidia card you can run Freesync in G-sync compatibility mode. Make sure you set your refresh rate to 165hz.
Reactions: VirtualLarry
