PC Gaming Build Help
Status
Not open for further replies.
Jake4697
I'm kind of new to PC gaming, but I've been doing a ton of research so I know most of the important stuff. I've put together a gaming build for around $700-$800. Does anyone have any suggestions for what I should change to improve the build but still stay on budget?
Computer Build-
Case- COOLER MASTER HAF 922 RC-922M-KKN1-GP
http://www.frys.com/search?
search_type=regular&sqxts=1&query_string=HAF+922+&submit.x=20&submit.y=10&cat=0
Mother Board- ASRock 990FX Extreme3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Produc...scrollFullInfo
Processor- AMD FX-8120 Zambezi 3.1GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8120FRGUBOX
http://www.newegg.com/Product/Produc...103961Graphics
Card- SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (100315L )
http://www.newegg.com/Product/Produc...82E16814102908
Hard Drive- Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produc...82E16822148840
RAM- Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 996988
http://www.newegg.com/Product/Produc...82E16820226184
Power Supply- RAIDMAX Blackstone series RX-700AC 700W Continuous Power ATX12V V2.3 / EPS12V V2.91 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Produc...82E16817152042
CPU Fan- Still haven't found one
Disc Drive- SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM http://www.newegg.com/Product/Produc...82E16827118031
Wireless adapter- Rosewill RNX-N180PCe Wireless Adapter IEEE 802.11b/g/n PCI Express Revision 1.1 Up to 300Mbps Wireless Data Rates 64/128-bit WEP (Hex & ASCII), WPA(TKIP with IEEE 802.1x), WPA2(AES with IEEE 802.1x)
http://www.newegg.com/Product/Produc...82E16833166063
Thanks 😀
Some of the important things that we would need answered are your budget and goals. You listed that your current build is between $700-800. Is that what you want to stay between? As for goals, the more specific the better. The easiest way to define these is typically based on the monitor that you will be using. For example, if you want to be able to use High settings in a game (considering this scale: Minimal, Low, Medium, High, Ultra), but your resolution is only 1680x1050, you won't need as powerful of a GPU as you would for 1080p.
Yep, your budget and ultimate goals will allow better responses, otherwise, you'd get folks throwing all kinds of stuff at you, whic in turn would cause more confusion. Be more specific.
Al
Status
