1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Graphics processing,Architecture softwares, AutoCAD, 3D Studio Max, photoshop etc.; other purpose include using it for internet browsing, downloading, Microsoft office, watching HD movies, songs etc;
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: yes
3. What is your MAX budget?
A: Maximum $650-$750Approximately Indian Rupees-35000( Let this not keep you from providing your inputs.Whatever you recommend.... I will check availability here in India.)
4. Planning to overclock?
A: No
5. Which OS are you planning to use?
A: Windows XP or Windows 7
6. How much hard drive space is needed?
A: Minimum 500GB
7. What resolution will the screen run at & whats the size of the screen you want?
A: 19" to 22" Monitor;
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest)
A: 8
9. Have you ever built a desktop before or will this be done by an assembler?
A: I myself have built systems and know how to do it. I want inputs on current high performance, good value components;
10. When are you planning to buy the system?
A: Withing next 2 weeks (anytime between 27th august - sep 10 2010)
11. Are you one of the types looking out for "future proof" configurations?
A: Yes, At least it should be future proof for 2-3 years;
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention.
A: CPU coolers,
13. Which city do you live in and are you open to buying from shops from other city/states?
A: bangalore or Chennai, India. Let this not keep you from providing your inputs.
14. Mention any other points if deemed necessary
A: nothing as of now
A: yes
A: No
A: Minimum 500GB
A: 8
A: CPU coolers,
