PC DVD drive region code
MetaDFF
145
To my understanding all PC DVD drives have a fixed number (5) of changes that are allowed before the drive is locked to a specific region. I was wondering, how does the drive determine the region to lock itself to? Is the region determined from the DVD discs that are inserted into the drive? (I suppose that is the way stand-alone players work correct?)
I know in Windows device manager you can manually set the drive region in the DVD drive's properties. I was just wondering if inserting a disc from a different region will result in a change in this region setting.
oynaz
2,449
This limitation can be removed from most drive by a simple firmware upgrade.
Yes
No, the manufacturer sets the region code (if they want to).
ForumMaster
7,792
Yes
true. i have a Sony DW-Q30A drive which is actually a Lite-On drive. it found some software that can reset the counter. i can change the region code as many times as i want.
we bought a dvd/vcr player. i searched on the net and disabled the region code.
MetaDFF
145
Yes
So that means by inserting a disc that is not in my region into the DVD drive it is going it immediately and automatically make the region change and reduce the number of changes by one?
ForumMaster
7,792
Yes
nope. you just won't be able to play it and windows will tell you so and offer you the ability to change it.
oynaz
2,449
...and you normally have 5 changes before the drive locks.
But just disable the feature.
