Hi,
I have built a PC with ASUS M2A-VM motherboard, AM2 3800 CPU, 2GB RAM, One Video Capture Card and a Sound Card. OS: Vista Home Premium.
When ever I shutdown my PC or when my PC goes into a standby mode it sometimes does not startup when I press the power button. Note that it does not happen always when cold starting. It does happen a lot when starting from standby.
I have to remove the power supply cable or switch off the SMPS and then wait for about 20 seconds (anything less than 10 seconds doesn't seem to work) before pressing the power button on the PC for the PC to start.
During Cold Start: When the PC is completely turned off, pressing the power button powers the PC for only a second or so. The CPU fan rotates and then everything stops. I have to remove the power cable for 20 seconds and then reconnect it for it to start up properly.
Start from standby: When PC is in standby mode, pressing the power buttons does nothing. I have to remove the power cable and reconnect it after 20 seconds to start up the PC.
I think it is not related to the OS. I have also upgraded to a server level PSU (500W). My suspicion is the BIOS but I am not sure what I should look for. The last time I upgraded the BIOS it is has royally screwed up everything and even failed to recognize my SATA II HDDs. Therefore I am wary of any BIOS upgrades unless it specifically solves the problem.
I would greatly appreciate any help.
